Just wondering what peoples thoughts are on water butts? I had previously read on here and other places that because water is so "cheap" that they usually arent worth it but as the cost of water is rising and most likely to continue then I thought it might be worth checking?
From memory I pay about £2.50 per m^3 of water (incl sewage charge etc) and a cheap water butt from Wickes holds 100l at a cost of £20. From google 1m^3 = 1000 litres so the cost per full water butt is therefore 25p if my maths are correct?
Average watering can is 10l so the cost per watering can is 2.5p which means the break even point is 800 watering cans?
If my maths are correct it still doesn't really seem worth it? Furthermore I would look at pumping the water via a hose rather than using watering cans so seems even less worthwhile?
