Morn'in everybody,
I have been doing a lot of research of late on a design to help chill my 3 mac mini servers I currently run for different things, they are all intel base core duo machines. Right now I am having to run them in a closed cabinet due to space. An idea I have had to use use the following
1. aquarium chiller
2. 4 x Radiators with fans on them
3. Pump and 1ltr tank
I plan to mount a small Radiator under each Mac Mini and have another in front of my synology NAS box. The idea is to chill the water using the chiller, and then pump the water into the radiators were the warm air will be chilled down when it is forced through the radiators. bit like a small split unit A/C unit
So my question is does anybody know of a good small water chiller I can use?, or have any other idea's on how to chill the water that I can investigate.
I have already tried using just fans in the unit which did not work, the last thing I have tried was putting in an extractor fan but nothing seems to reduce the temp of the equipement
1. aquarium chiller
