Hey guys, This might be a little long winded but wanted to try and include as much as possible , Ive developed a bit of a puzzling issue following a few changes ive made to my rig, and don't think it'll be one of the usual problems that can be solved with a bit of forum digging.......
With the launch of the new 10xx series cards id developed a serious itch to do something with my rig, but right now cant justify the cost of upgrading to a newer card as im running a pair of Asus 970 Strix's.
They do pretty much whatever i need at either solid 60fps or just below ( Ark being the exception ), main issue i was having was with noise, even with the quiet coolers on the strix cards prolonged gaming with good overclocks ended up with some fan noise. So i decided to go Water cooled for something to do and to drop noise levels.
Ordered a pair of kraken G10 AIO brackets and two Corsair h55 AIO coolers, and a pair of Noctua fans to replace the nasty white ones on the g10 brackets.....installed and started testing.,straight away temps are AMAZING, dropped from 75-80c on the top card after a long bench down to 56c MAX.
Now my previous best OC was around 1350mhz in Sli as id set a thermal limit in afterburner at 80 deg, so cards stabilized at around that after a prolonged bench.With the new coolers ive managed to get that up to 1501mhz, basically limited by card stability, start getting artifacts if i go much higher.
Now this is where i think my problem starts, Power limit has been increased to 120% in afterburner, and whilst benching the cards are showing around 118% maximum power usage and just under 1.2 volts, again temps still holding steady just below 60c after being thoroughly warmed , however after 4 or 5 loops of 3d mark stress testing without any real warning....Black screen, system restarts....... on boot i will have lost one of the two cards, doesn't even show up in Bios on PCI/DIMM POST. If i allow it to boot windows Nvidia control panel only Shows a single card also. However wait 10 minutes and reboot.....All is well, both cards showing in PCI / DIMM POST, and sli back working on win loading.
So this leads to the question, anyone seen or heard of anything like this? As its the first time ive been able to push these cards in Sli, always been limited by card temps in the past. Under powered? Overpowered and causing card to shut down? Im unsure...
Tried a few differnt combinations of lowered and raised power limit, with no real effect. Dropping the core clock to 1400mhz does eliminate the problem but surely i should be able to run a 1500mhz clock with temps so low and no visual artifacts?
Thanks in advance for any info or help.
