Water Cooled Case...........Which One?
1 Feb 2004
UK
Hi all looking to buy a new case (£250 max spend) soon and want to go water cooled probably two loops. I am not sure which case, but whatever case I go for it will have to last for a few years and have enough options for expansion if I need it? I was looking at these cases..........Lian Li V2100+ series (which one?) Silverstone TJ07 orTJ10? Are there any other good choices out there with similar build quality?
have a look at the antec p190,ive got one but dont have water cooling but love the size of the case and the future upgrade option's.
im looking at keeping my p190 for many years to come as well.
TJ07 is perfect for single loops, nightmare for anything more.
V2000 / V2100 is good for multiple loops as long as you don't mind cutting holes in your case.
A70 / A71 is a triple loop dream, 240 in the roof, 240 in the front, and a 240 on the floor (I think anyway, I have yet to confirm the floor radiator)
