- 12 Oct 2014
- West Midlands, UK.
Hi everyone, this is my first post and my first water cooled PC build!
-Please feel free to offer up any encouragement or advice that you have
My objective for the build is a small form factor pc with some oomph. I enjoy gaming, no surprises there, and have Oculus Rift DK2 on order -woop! I also plan to work with 3d rendering/printing, some audio and video as part of my work.
I hope to create something that looks good and performs very well while being quiet. Of course I'll be overclocking, but nothing major to begin with.
Onto the build...
My Spec:
Water Cooling:
Now for the tech porn...please excuse the quality of the some of the images, the lightings not ideal and I've been too excited to sort that out!
Onto the build...
My Spec:
- Fractal Design Node 804
- ASUS Maximus VII Gene
- Intel 4790k
- Corsair Vengeance 16Gb 2400Mhz
- Crucial M.2 240Gb SSD
- Seagate 2TB Hybrid HD
- ASUS GTX 980 Ref Design
- Corsair RM1000
-packing a fair bit more power than necessary here as I plan to SLI in the nearish future, and may take the leap to Haswell-E in couple years. - ASUS AC1900 dual band wifi
- Black Braided Cabling
- White LED lighting
Water Cooling:
- XSPC Raystorm
- 2x Hardware Labs ICE GTS-Lite 240
- 4x Noctua F12
- 1x Corsair SP120
- 1x Corsair AF140
- Aquatube Delrin Res Black
- Aquastream XT Pump
- Aquaero 5 LT
- 12x Monsoon 10/16mm Free Centre Matt Black Fittings
- 1x Koolance 60' swivel Fitting
- 1x Koolance 90' swivel Fitting
- Monsoon Quick Disconnect
- 10/16mm Orange Primochill Primoflex tube
- Mayhems Pastel White
-unusual choice here. As the tube is orange, the only place you'll see the liquid is in the Res, which will be lit using the Aquaero RGB LED, which gives a quick visual indication of temperature.
