Recently bought a new PC which has a water cooler. On more intense games the PC vibrates, it sounds like it coming from the water cooler fans at the top of the case. I don't think the cooler is faulty and it doesn't sound like air bubbles (I looked it up on YouTube and its not that). I suspect it's just normal vibrations, its only when the RPMs go up that I hear it but I've never had a water cooler before. I don't know if I can do anything about the noise? If not then I might look at getting a PC mount to mount it under the desk instead.
It's a Kolink Umbra Void AIO 240mm Performance aRGB Water Cooler, the case is APNX Creator C1 Black Mid Tower Case. I've tried putting some rubber furniture feet underneath the case but because the noise is coming from the top it makes no difference.
Would be good if I could find a way to dampen sound so open to suggestions that might work.
