Water cooler - ideas!
25 Sep 2009
Durham uk
I am wanting to use water cooling for the first time, rig is i7, 4870, asus rampage, 6 gig viper tri chan. Mainly want cooling for cpu just not sure where to start
sorry 4 double post in hardware, new to forum! :)
The Corsair H50 is an excellent all-in-one water cooling set for socket 1366, ideal for people new to water cooling. It beats the top-end air coolers at similar price, and is on offer at the moment for only £54.99 :D
Ah nice one! so its self contained, like i don't need a reservoir or anything? And will my thermaltake m9 bis big enough for this rig? trying to avoid new case if i can but its not a massive drama :)
Yup, its all set up and ready to go! The only requirement really is that you have space for the 120mm radiator/fan, ideally on the back of the case. As long as you have that, you're all set :)
Should fit into your case, as they fit in antec 300's antec elites and the like, so you should be ok.
But best to wait to see what others say too.
If i wanted to custom build my own kit for my GPU and cpu what would you recommend?
full build:-
asus rampage mobo
saphi 4850
i7 920
6 gig tri chan viper
thermaltake M9
what can you fit into your case....a quad RAD? when buying WC kit its best to go over the top, that way you future proof it (the same as a PSU purchase)
Yea WC put u into a different league i've just upgrade from a gigabyte 3d aurora to a lian li v2110 just so i can fit a quad rad inside the case (but then again im crazy as i thinking of trying to get a golftown (6core) to 4gig when it comes out).
But i would say after looking at ur case u either have two options
1 Corsair H50 (it will fit in ur case no problem the only problem u have is that u wont have a great amount of air moving through the pc so u will need a pci slot cooler (lian li do a great one))
or
2 Build a custom small pc wc kit and have the radiator mount on the back (however i would suggest at least a 360 rad with i7 for future proofing as sayso said)
The kit i would suggest would be
CPU EK supreme (so u can fit it to as many different type of socket mountings as possible)
GPU EK HD 4850 Acetal Full Cover I would say full cover is the only way to go really now, as the universal ones just wont be able to handle anything better than ur current gc (probably not even handle ur card). But then thats all down to the fact that were never only just adjusting the core speed of graphic cards anymore well its not our main aim. but u can add that at a later date.
Radiator I'm not sure on this really but for ur cpu u need 360+ (if ur gonna cool both cpu and gpu at some time) i would probably go for one that just fits ur situation (thin and long).
Res doesn't matter thats all about choice however u will have to have it fitted outside as u really don't have a lot of space in that case (apart from a bay res maybe)
Pump well as really there are only two pumps in this world the Laing DCC 18v (more powerful ddc version) and the laing D5 (gonna get the different part for it to use compression fittings on mine :P) the D5 being the more powerful one.
Tubing pretty much 1/2 if u want chunky 3/8 if u want thin the advantages and disadvantages here are pretty simple.
really my feeling is if ur going to go wc go jump straight in the deep end. Just remenber its all about buying parts that will last so u will end up spending about 150 maybe 200 quid at least but if u take care of ur parts they can last u as many upgrades as u want. So its really do u want to buy something cheap but good now (that might not be so good later) or buy custom and when one part becomes crap it doesn't mean ur scrapping the whole thing. The benefit though about the H20 is u have watercooling running and ready in second doing it custom will take u days :P.
it's ur call both are good options.
(Btw hehe this will be my first watercooled system built :D but then strong with the force i am :p )
If you have very little room, either get a DDC with a res top or use a T-line somewhere.
As for tubing, go with 7/16" as a great compromise between size and flow.
Yea tubing is just about finding the right balance for u same goes with rad really but hes right though i would go for a ddc in ur case as it will make it a lot easier to fit to somewhere especially if u have the res top (a lot less tubing).
Well i might move to a antec case then, i want it to be a good system as i dont want to upgrade for a while after this onecould anyone help me with a list of parts for the 150-200 £ mark? am looking at the antex 902 case also. Thanks guys for the help
btw crazy post times as i work shifts ><
Hmmm good point, first wc kit I have done so not to sure, will have a look at cases tonight when I get in. Did not want to spend more than 80 on a case. Ahh the epic struggle goes on, its fun tho!
All in one solution for about £200, I've seen it for £172 at a UK store which could be confused with this one.
http://www.thermaltakeusa.com/Product.aspx?C=1161&ID=1412
The Kit in this has been compared to the top Alphacool systems as well as others and beats them.
Along with an extremely nice case.
Don't buy the thermaltake system. Just don't, it'll be crap.
Up to £80 for a case suggests a dremel will be involved, are you happy cutting it up?
Thermaltack beats an Alphacool system? not if it was a fair fight it doesn't! Look at that radiator! Incredibly ancient design proven to produce crap cooling compared to more modern types. "Superb P500 pump". Don't make me giraffe.
If you wish to simply read and believe advertising, what is the point of this thread?
EDIT:
If you wish to simply read and believe advertising, what is the point of this forum?
/EDIT
(Apologies to the OP)
am going for:-
i7 920, 5850, gigabyte GA-EX58-UD3R, viper 6gig 12800,
laing ddc+1 18w 12 v, black ice gt 360 rad, ek supreme, XPSC single bay res and XPSC 1/2 1m*2
Need a case i think lol, any thoughts would be good. have a week off from work too, looks like i have my own work cut out for me!
thanks
