Have just been reading up a little more on water cooling two things, please correct me if l'm wrong.
1:That a Full Cover does not make that much difference to your GPU all round performance? A GPU Block will do just fine, my case is a FTO1 both the 180mm Fan's will cool the 5870 GPU PCB when fan cover's, etc, is removed.
Playing BC2 every thing is set to high,vsnyc-false >AAx2 / AFx4, etc, according to GPU-Z Max Temp > 67'c / Fan at 30% / OC 875:1250mhZ.
2:Tubing Dia 16:10mm is fine and 16:13 does not make that much difference to temp's / performence of the loop?.
Cheers Guy's.
Cheers Guy's.
