Hi, my system is below in my sig, the only change I've made is too install water cooling over the past couple of days. Since then I've not be able to get into the bios screen, nothing is displayed at bootup and my LCD briefly switches off, I can see it's gone into the bios setup by my little post LCD screen. If I try to wake the Dell I get the message that it isn't receiving any input, however I leave it to continue booting it will go inot Vista fine and I get a picture and can run benchmarking, games, whatever.
It all worked ok before installing WC so I've thinking perhaps the cards aren't initialising themselves at startup, perhaps because of no fans?
I have tried all the DVI outputs, disconnected the crossfire links to no avail.
Many thanks for your help....
ChrisC
ChrisC
.... would you consider RMAin the card cos when it comes to selling them on not many ppl are gona want a card that wont let them look at the bios. I would tbh as you have 2 cards.
after all the effort, and cost, this has taken me.
