Water Cooling - Adding Components
17 Jun 2008
About to start my first water cooled pc hopefully it goes well lol.
Later i plan to alter it by adding a gpu block and maybe a bigger radiator, was just wondering what would be the best way to add components.
Any tips or tricks u guys use to make adding stuff easier (and less messy :p)?
Thanks
Buy the best bits to form the base of your loop at the start, buy cheap buy twice if you are planning on adding more and more parts as you go.
Good rad + pump from the start would form a very nice base to build from.
The best bet is to drain the loop. Adding a T-line or having a bleed valve at the bottom of the loop makes this easier. Otherwise just be careful when uninstalling it.
