As the title says I need some advice. I'll start off with what I have then follow up with some questions.
XSPC 750 dual bay resevoir pump
TFC Xchanger 240 rad
TFC Xchanger 360 rad
XSPC RASA CPU block
EK-FC7970 Full Cover Waterblock
Now the questions.
Firstly. Will the pump I have be sufficient for all of this?
Secondly. If not would just a the single 360 rad provide enough cooling for both blocks?
Fans aren't an issue. I have plenty to choose from already ranging from silent low rpm ones up to 3000rpm Scythes.
Thanks.
Edit: I now realise the watercooling section would have been more suitable for this. Anyway to rectify this?
XSPC RASA CPU block
Now the questions.
Thanks.
