Hi i have a TT Kandalf lcs and it is supplied with its own water cooling this is my 1st water cooling project and have a few questions ...
1st one is what is the outer diamiter of the tubing i know the ID size is 3/8 but no idea on the outside is cant find any info on it any where all i knwo is it could either be 1/2 or 5/8 as i want too either change the tubing too gloss black or fit some uv blue anti-kink coils and would like them to be the right size
2nd is how it layed out the instruction that came with my system says too put it as
(Pump then its connected to the Reservoir)-(CPU block)-(rad)-(Reservoir)
i was thinking if it would be better going
(Pump)-(Rad)-(CPU block)-(Reservoir which is connected to the Pump)
as this shoul make sure the coldest water is gettin to the cpu 1st with the most preassure please correct me if iam wrong
3rd is it worth keeping the cpu block it came with ? and if so what would be a good replacement ?
4th and last is if i changed the cpu block could i swap fittings over as i think these look a lot better than a tie wrap around a barb
Thanks in advance Mr. May
