Hi Folks,
I have received most of the items I need to set up my first water cooling loop today. I am just waiting for a few more items (case and fans) before it's all ready to go. I have been looking around for guides on the process involved in setting up the loop but haven't had much luck.
My plain is
1.) Cut rad hole in top of case + fit rad + fans + grill.
2.)Drill holes in the bottom of the case and attach pump securely on and vibration base
3.)Fit barbs to all items and then fit to gfx card and processor.
4.)Install items into pc and get everything screwed into place.
5.)plumb up the loop, using cable ties to make sure the connections are airtight on the barbs.
6.) fill loop with liquid.
Can you please comment on the above and let me know if that looks ok.
What I am a bit unsure of is how the loop fills with liquid. I will have my case set up as per picture below. The case is a Lian Li A05B so it have an inverted motherboard layout.
Do I need to have the pump turned on for the liquid to make it's way around the loop. What method should I use to get all of the air bubbles out.
What words of wisdom do you have for a WC newbie?
Thanks
My plain is
Thanks
