Water Cooling Advice
15 Apr 2016
UK
Hello And Thanks For Looking
Colour Scheme : White And Black (So White Coolant Or White Tubing)
Experience : 0% Never Ever Water Cooled Before But Built About 5 PC's
What I'm After :)
Watercooling parts for the CPU and Both GPUs (GPUs can change just needs to be a 1080. Any Idea when Titan X (Pascals Will be available?)
Please Check If The HB SLi Bridge Is Correct Or Do I Need The 3 Slot One?
This Is What I'm Wanting Watercooled
My basket at Overclockers UK:
Total: £3,533.33
(includes shipping: £23.40)
Thanks For Your Help Just Wanting To See How Much More Im Looking At
Pretty sure its direct only far as I know, one other supplier does them but you have to buy it in a pre built machine so is not of interest to you.
By the way your signature is either wrong or your channels been removed.
