- 28 Dec 2006
- Epsom Downs
Ok i'm just waiting for my power supply to arrive, but lookin at my system i have decide to water cooling.
My resaon is the cpu cooler i bought ( Arctic Cooling Freezer 64 Pro ) needed some of the fins bent to get it over the heat pipes on my ASUS m2n32-sli deluxe board. I've readed loads of reviews on this heat sink and it seems ***, but i'm not sure if it will be want i want.
Arrowed is where i had to bend 4 fins to get it to fit
I've got a Socket A water system, and wanting to cut off the block and stick on a AM2 block, but i'm not sure on what one to get. i'm not worried about taking the board out as it's not running yet. but i have spent LOADS on this system and don't want some thing that will crack and kill it.
what block do ppl recomend ?
Cheers
Cheers
