Hi there,
i am new to this forum and i hope this hasn´t been discussed a hundred times. I am not a native english speaker so please excuse my wording.
I´m wondering if someone has experience with full negative air pressure in a water colled system by using only exhaust fans and no input fans. It really bothers me to buy the newest RGB Fans for 30$ just to mount them upside down and stare at cheap sticker on the back while all this RGB-goodnes lightens the inside of my radiator... I found some tests stating negative pressure is better for overall temps. There is even a test by Linus showing that there is less dust entering the case than in a neutral pressure environment. But all these tests refer to air colled systems as far as i can see, so i wanted to ask if somebody gave it a try or even runs a system like that and would like to share their experience?
For those of you who are interessted, i am running a LianLi O11d with one 360 radiator on the bottom and one in the top so temperatures are no problem its all about the look
.....with all that ARGB-madness going on i wonder why nobody offers fans in Pull-configuration.
cheers
Dennis
cheers
Dennis
