I've been planning my water cooling setup for a few days now. I've got most things covered (except for deciding whether to use cylinder/bay res) but I just realised I may have an issue with the colour scheme.
My plan was to use red lights on the case (fans, leds etc) and have green uv tubing however it just occured to me that it may cause a strange blend of red/green/purple once I add the uv lights. How bad do you think it will be and is there any way to get the tubing lit up without having the uv dominating the case?
Also while I'm here I figured I'd ask about the whole red/green as I simply can't find any examples of anyone who has used green tubing in a red-lit case. Do you think it will look naff? What colour schemes would you recommend if so (I know some people like plain simple themes, but I really do want it lit up, though not looking distasteful). I'm not keen on an all-blue theme either incase it gets suggested.
but I'm going to do it again once I get a new pump and res and also get some uv cathodes and maybe uv LEDs in the pump top and res.
