- 13 Apr 2009
I currently have 2 cooling loops.
Loop 1 = Pump 1 > Radiator 1 (240) > CPU > MOSFETs > Voltage Regulators > Reservoir > Pump 1
Loop 2 = Pump 2 > Radiator 2 (480) > GPU > NB/SB Full Block > Reservoir > Pump 2
The reservoir is common to both loops. The pumps are both D5 vario.
Would I benefit from a 'single' figure-of-eight style loop?
For instance,
Pump 1 > Radiator 1 (240) > CPU > MOSFETs > Voltage Regulators > Pump 2 > Radiator 2 (480) > GPU > NB/SB Full Block > Reservoir > Pump 1
Normally I would try it out, but I'm getting a bit tired of the two day experiments.
For instance,
