a big hi to all,
socket 775
motherboard asrock penryn 1600sli-110db
cpu pentium 4 model number 630 3ghz 800mhz 2mb prescott
ram 667 ddr2 2gb x1
maxtor 250
graphics card nvidia geforce 7300 se/7200 gs
cooling artic pro 7. idle temp 42c load temp 52-53.
voltage, cpu-z says 1.464-1.496
voltage, vtt 1.375
voltage, dram 1.85
voltage chipset 1.250
overclocked to 3.9 at the moment,15 x 260
i all so have pentuim d 830 2.8gz 800mhz 2mb smithfield,and
pentuim 530 3ghz 800mhz 1mb prescott. im not sure wich one i
should be using for clocking so if any one has an idea please say.
1st do i have to have seperate Reservoir and pump or can i get a pump Reservoir,
eg XSPC Bay Pump Reservoir - Clear
parts list.
cpu blocks
CPU Waterblock OCZ Hydroflow HF-MK1 CPU Waterblock £29.07
cpu EK Supreme LT CPU Waterblock for Intel 775 & 1366 £35.99
radiator
Swiftech 1 x 120mm Radiator with Reservoir : MCR120-QP-RES £ 23.49
Swiftech 2 x 120mm Radiator with Reservoir : MCR220-QP-RES £ 39.99
can you also tell me what size make model pipes to use? fluid i should try
i know every one has their favourites so please say.
thanks for taking the time to offer any help and advice,thank you in advance.
i have joined a few other forums so i will be putting this on those as well,im
a proper newb to water cooling so if i ask a daft one please be gentle.
socket 775
ram 667 ddr2 2gb x1
maxtor 250
voltage, vtt 1.375
voltage, dram 1.85
parts list.
cpu blocks
radiator
