I was going to replace the air cooling of my cpu to a different cooler as when i had a water cooling kit it leaked on me, but I want to cool down my cpu and later down the line my 5850 and another 5850 when i get my other card.
I want to get lower temps on AMD Phenom II x4 940 cpu (gpu's when the water blocks are out) my 5850 at the moment is at 43c cpu is at 40c I will upgrade to an i5 / i7 or wait for new amd or intell processors so I want something that should handle them overclocked.
I want it to look smart inside aswell (look cool) as the case is next to me and being an antec it has a window so I can see inside all lit up blue.
I don't want to spend loads so under £200 if possible lower down from 200 the better lol.
I have antec 902 case, 8gb ddr2, 5850 (soon to be another in xfire) creative sound card that's old and will be updated soon and a Asus M3A79-T Deluxe amd2+ motherboard.
But please tell me what parts you think I should get and if you have the same case with water cooling say what parts and upload some pictures if possible.
Here are some images
looooool *
lool but i will save and get the best that i can, do oc sell all them parts?
