- 7 Jul 2008
- Newcastle upon Tyne
I have a corsair air 240. The cup is cooled with a h100. I decided to water cool my gtx 980ti using a corsair hg10 and h55 water cooler. However to accommodate the extra rad I had to mout it in the campartment where the wires etc are hidden. When running a game the gpu temp is 69 deg which is much better than air cooling plus quieter.
The problem I need you help with is the heat being generated in the case. The mono temp is now hitting 50deg and the compartment where the rad is feels hot.
Could I, instead of drawing cold air in reverse the fan.
