Hey peeps, how are you all?
I am just spec'in up a new Computer which I am gonna buy next month. At the moment I run a 2800+ with a 6800GT and it's sooo noisey, I also have 3 case fans to try and keep the damn thing cool! So I was thinking about water cooling my next PC to try and make it quieter.
I have used the search function many times and read many articles and I cannot decide on a system to use. the Reserator 2 looks very good although the Swiftech sounds like the best bet. I want to use my current case which is a Coolermaster ATC-210 (i think).
I have built many PC's but I have never done water cooling, I came here for advice about my current PC as you guys rock and its lasted extremely well, thank you!!
The spec i am thinking of going for is something like a AMD 6000+ X2, Asus mobo, 4gb RAM (dunno what make), 8800GTX, Sound Card. I am guessing by this that the only 2 things i would have to cool are the GPU and CPU? as the mobo is already passively cooled?? or doesn't it work like that?
Thanks a lot,
James.
Thanks a lot,
James.
It's still too new for me.
