Water cooling help
19 Feb 2007
Northampton
Ok im a total newby at watercooling, id love to get watercooling but i dont know what to get and how to attach it to my case, case is nzxt lexa classic, many thanks in advance
You may find the information contained within the guide useful including the links.
Article by weescott "Guide to Overclocking & Cooling"
http://forums.overclockers.co.uk/showthread.php?t=17803239
Personally if you have a budget a custom water cooled system would allow a higher "quality" selection of components over a standard bundled W/C set up. It reduces the need to Upgrade and allows a higher degree of flexibility.
If you can stretch to £200 then its definitely worth getting a custom kit, I think you can even get one for CPU only for £150, then a extra £50 for GPU.
Think mine was £240 for CPU, GPU, Radiator, pump, tubing, Feser One, barbs. Not shabby kit either, all brand new and best stuff you can get :)
Better performance then the Swiftech kit!
