so im doing a new build and i am new to water cooling so was wondering about the fittings all will be done in my corsair 800d. also what is the safest fitting and the best size thanks.
The specs are
cpu (got)
I5 3570k
motherboard(thinking about this)
http://www.overclockers.co.uk/showproduct.php?prodid=MB-390-GI
Ram(got)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-017-SA
psu(got)
http://www.overclockers.co.uk/showproduct.php?prodid=CA-029-CS
so these are the main parts im think about
cpu block
http://www.overclockers.co.uk/showproduct.php?prodid=WC-022-KA
pump
http://www.overclockers.co.uk/showproduct.php?prodid=WC-142-XS&groupid=962&catid=2141&subcat=2142
and also what does this kit do
http://www.overclockers.co.uk/showproduct.php?prodid=WC-328-BP&groupid=962&catid=2141&subcat=2143
rad
http://www.overclockers.co.uk/showproduct.php?prodid=WC-030-BX&groupid=962&catid=1523&subcat=1526
res
http://www.overclockers.co.uk/showproduct.php?prodid=WC-321-BP&groupid=962&catid=2133
or if this fits
http://www.overclockers.co.uk/showproduct.php?prodid=WC-323-BP&groupid=962&catid=2133
for fitting not sure which but has to be black or red.
also thinking of getting a 7870 as a gpu so would want to water cool that in the future so is that enough.
There is no budget as i am buying parts as i get paid but not looking to go over board at the end dont want to go over about £350-£400.
i like the look of these fitting
http://www.overclockers.co.uk/showproduct.php?prodid=WC-238-BP&groupid=962&catid=1529&subcat=1852
also does this void intels wararanty http://www.overclockers.co.uk/showproduct.php?prodid=WC-350-EK
The specs are
cpu (got)
I5 3570k
Ram(got)
psu(got)
cpu block
pump
rad
res
or if this fits
check my sig for build log)
