Water cooling in a Antec SLK3800BUK Black Quiet Midi.
I cant find any pics of the inside but it looks pretty small. The rad would probably have to mounted externally or in the roof if there's room
I could move the DVD drive down about three slots and that would give me room for 2x120cm fans in there possably the RAD but other than that my case is more or less full.
What about if i purchased a case with watercooling already installed would that be better?
Also does the water kit run off the psu ?
Well depending on how you want to build it not many tools are required. Could also put the rad on the back, which will be simpler
WAS, but now you say that i think i change my mind:P
What others is there and where could i get them ?
Danny`here on irc if you want to talk :)
I wouldnt really buy a case with WC pre installed, chances are you wont get the parts you want or the exact case you want. Are you looking to buy a new case as well?
really just the cpu for now but not all 180quid on that then maybe move on to the gfx card later just make do with a zalman thingy for my graphics.
Then i maybe able to keep my current case.
Dont mind second hand at all.
