- 1 Jul 2007
I think i know the answer but gonna let some-one back it up.
But is this any good? I realise the originial case aint worth that much.
Modified Chieftec Full Tower with mesh design.
Alphacool NexXxos Pro III Radiator with tripple 120mm 14dBa fans.
Eheim 600 Station II 12V pump with combined plexiglass reservoir.
Alphacool NexXxos XP Light copper water block.
AMD XP, AMD 64, Socket 754, 939, 940, Intel Socket 775 CPU adaptors.
Connected with 10mm tubing and pre filled with Tec-Protect-Plus fluid.
And how much of a market value would you put on it (although your not allowed to do that in these forums), pondering it as a possible silent/quiet case.
