Hi, folks.
I'd like to reduce the noise output of my PC, primarily the noise of the graphics card. I have a Twin Frozr II cooler, which, as I've seen mentioned on here before, is prone to bearing problems with the fans. I used to get a buzz in a very small fan speed range, but now I can hear it slightly even at minimum fan speed and it's driving me crazy, so I've decided to look into some water cooling.
The case is a Fractal Design R3. I was hoping someone who's done water cooling in one of these before could shed some light on what sort of layout I could go for. At first glance, I can get a 240mm radiator in the top, but I'd ideally like another one, but I'm not entirely sure where I'd put one.
The rest of the system specs are:
i5 2500K
8GB Corsair Vengeance Low Profile
MSI Twin Frozr II GTX 580
2 x 2TB Samsung F4 (with an SSD to come at some point)
Antec 650w TruePower New PSU
As for fans, I have a 120mm Fractal Design fan front and back, a 140 in the top, and a spare 140 that used to be on the side until I decided to put the noise dampening back on to try and protect my sanity.
Any advice/input would be appreciated. Do I put the kit together myself? Are there any good kits out there? Any brands better than others? As far as budget goes, I'd like to do this as cheap as I can without cutting too many corners, so will probably see what I can source on the MM.
Thanks
i5 2500K
Thanks
