Water Cooling in a Lian-Li PC V1000 PLUS
SBD
SBD
24 Oct 2007
Leicester/Norwich
Hi all was wondering if it is possible for me to house a 120.2 rad, pump, cpu block and rez if needed in my Lian-Li PC V1000 PLUS case.
I'm looking in my case and i cant see where it would fit, i don't really want to mod the case tbh since i have never tried anything like that before :p
Would it be best to try and find a zalman external rad and then get the rest. Has anyone managed to fit a water cooling set into a V1000 before? I was thinking maybe get 2 120.1 rads and fit them where both my 120mm fans are atm would this be possible?
The innovatec stuff as pictured will be a bit restrictive esp as hsa lots of fittings and elbows and norrow bore tubes.
You might be able to get a 120 rad
at the bottom front
in the drive bays (would need grill bay covers for airflow and leave possibly only 1 bay spare for drives)
at the rear fan location (thinner rads easier to mount here than thermochill ones)
a 120.2 is not going to fit without cutting the case
