water cooling kits any good ?
23 Aug 2007
Hay all saving up for a new pc atm should be looking to get one in a months time
but i was thinking that i never had water cooling and i would like to try have it lol
but not sure if them kits are any good or should i buy the stuff bit by bit ?
My case i have atm is a mozart TX so i got the room for water cooling and i will be overclocking the CPU when i get it.
so i was looking at Swiftech H20-220 Apex Ultra+ £200 seems a lot for me anyways so what would be the best way to go about this?
I wan't to water cool cpu/chipset/graphics card / hard drive i think you can and what ever else can be water cooled lol
what sort price am i looking at for a good system for a noob at water cooling lol
thanks
If you think £200 is a lot then forget cooling what you have listed. What is your budget? What are the reasons you want watercooling? Are you willing to hack your case to fit cooling?
yes £200 is a lot but it just means i would have to save up more for water cooling thats lol
budget would be £250 if i can't some good system for that then ill leave it i think lol
and reason why i wan't water cooling cause i will be over clocking the new pc when i get it and i think water cooling looks great :)
my case is a mozart TX i don't think i need to cut anything on as it was made for water cooling well so they say lol
You can get a good custom setup for CPU cooling for £200.
I paid £250 for :
1 x 12V Laing DDC-1T Ultra w/OCLabs XP Top Clear/UV Blue
- Barb Size: 1/2" Nickel Plated
1 x Zinc Plated Jubilee Wormdrive Clip 1/2" (10 Pack)
1 x *7/16" Masterkleer PVC Hose
- Hose Length: 4 Meters
2 x 1/4" BSPP - 1/2" Hose Tail (EK)
1 x XSPC Dual Eye Ball Bay Reservoir - Black
1 x AC Ryan 4" Dual CCFL UV Kit
1x Thermochill 120.2 Radiator
- Barb Size: 1/2"
2 x Feser One Cooling Fluid - UV ACID GREEN
1 x EK-FC88GT 8800GT
1 x EK-Supreme CPU - Acetal
1 x RadGrillz Thrust 2x120 Aluminium Black
Without GPU cooling you can get that for £190 :)
Don't botehr cooling hard drives, pointless!
No need for rans on the ram or hard drives
Ram will be fine , most PC5300 will run upto 400mhz without too much heat
Hard drives will be fine anyway, they work until high temps :)
ok dude thanks so i am looking at £800 for pc with water cool setup which not to bad
can't wait rollon pay day lol
Hi - have you got a kit list in mind? Water-cooling will let you push your CPU and GPU further but may be easier to get the same performance by spending the 200 on a better CPU or a dual graphics set up :-)
