water cooling leaking
9 Nov 2012
I have a OcUK Tech Labs Fathom All in One Custom Cooler 120mm which I have had for over 2 years. but have found it has started leaking where one of the pipes attaches to the cpu reservoir block thing is. what is the best way to fix it?
Hi,
I don't believe this can be fixed. Please remove it from the system in case it damages anything else. I would recommend contacting our supposed team first thing Monday to see what options are available to you.
You can call our tech support line or use the support section of the forums.
Agreed with the above, remove it from the system. See what options are available to you warranty wise.
If not and the one im looking at is correct. A new compression fitting or o-ring's. Possibly some new tubing should sort it out.
This is what I am thinking of getting. What do you think and have I selected the right size hose and fixings?
XSPC G1/4" to 7/16" ID, 5/8" OD Compression Fitting (Black Chrome)
https://www.overclockers.co.uk/xspc...mpression-fitting-black-chrome-wc-103-xs.html
XSPC 7/16" ID [16/11mm] High Flex Hose - Clear [1m Length]
https://www.overclockers.co.uk/xspc-7-16-id-16-11mm-high-flex-hose-clear-1m-length-wc-031-xs.html
XSPC X2O 750 Dual Bayres/Pump (Black) V4
https://www.overclockers.co.uk/xspc-x2o-750-dual-bayres-pump-black-v4-wc-186-xs.html
XSPC RayStorm CPU WaterBlock (Intel) V3
https://www.overclockers.co.uk/xspc-raystorm-cpu-waterblock-intel-v3-wc-385-xs.html
XSPC EX120 120mm Radiator - Black
https://www.overclockers.co.uk/xspc-ex120-120mm-radiator-black-wc-083-xs.html
XSPC
AMD Mounting kit for RayStorm V3
https://www.overclockers.co.uk/xspc-amd-mounting-kit-for-raystorm-v3-wc-382-xs.html
