I'm about to start building my watercooling setup next week and i was wondering what the recommended best loop order would be..
Loop order:
bottom of the case pump with res top pumping into CPU > GPU > rad (top of the case) > back down to the res top on the pump.
or
bottom of the case pump with res top pumping into GPU > CPU > rad (top of the case) > back down to the res top on the pump.
And the Rad fans question:
Rad top of the case with fans on top of it sucking air out.. or in?
or
Rad top of the case with fans blowing though the rad out the case or into the case?(tho was thinking blowing away to stop lots of dust being sucked onto the rad.)
kit list:
Laing DDC 1-T Pro 10W 12V DC Pump with XSPC Acrylic Reservoir top.
ThermoChill PA120.2
Swiftech Apogee™ GTZ CPU Block
XSPC Full Cover Razor HD 4870
7/16" ID - 5/8" OD Clear Hose (also some blue anti-kink coils)
Feser One Cooling Fluid - UV BLUE
2 x Xilence Pro Fan 120L 1400RPM 120mm - LED Blue
Loop order:
or
or
kit list:
ThermoChill PA120.2
