hi all
i have a few questions about cooling my system
i would prefer my system quite quiet or as quiet as i can get.
i have the antec 620 cooler at the mo which is fine it sits about 53degrees on full load OC @4.0ghz. it is in an antec 300 case
couple of questions then
1.i want to cool gpu as well as cpu is it better to have one big rad before cpu or have two smaller rads one before cpu and one before gpu?
2.inside or outside of case?
3.could i use the antec pump with a reservoir to get me started (single rad still)
4.which are the best bang for buck kits?
at the moment i have 6 fans whurrrring away cos graphics is a double fan jobby and it starting to annoy me cos its spinning loud all the time.
any help will be welcome.
thanks again
thanks again
, will be easier to setup, will look cleaner
