I have finnaly taken the plunge to the Watercooling world and I need help.
I have chosen a case for watercooling, the rads but I need help with the rest.
Specs for upcoming build:
NZXT Switch 810 Big Tower Case - Gun Metal
1 x XSPC AX360 with 6 Gentle Typhoon 120mm 1850 RPM Push-Pull
1 x XSPC AX240 with 4 Gentle Typhoon 120mm 1850 RPM Push-Pull
Aerocool Strike-X 1100W '80 Plus Gold' Modular Power Supply
Asus Z77 Maximus V Formula
Corsair Vengeance Black 16GB 1866MHz
I5 3570K (What is the best mount?)
2 x GTX 680 (Full block or invidual bits, will it be bottlenecked?)
What is the best pump for this loop, Which reservoir and pump.
Best fluids?, I would like a crimson red.
Cheers for the help.
. And either setup can leak, but that is what leak testing is for
