Water cooling - noob
21 Aug 2007
Hi all,
I am looking to invest a good water cooling setup, I know nothing about water cooling and have always had air cooling. I am sick of the noise of all the fans in my computer so I want to silence things with some water cooling.
I have a Thermaltake armor case with 200mm fan on the side panel, my system specs are Q6600 G0 @ 3.42Ghz, 4GB OCZ 6400, Gigabyte DS3-R, Geforce 8800GTX.
Ideally I would be using the water cooling to cool my cpu, mb chipset and graphics card.
I don't know if this sort of info has been posted before but would love some ideas on different wc setups etc. Cheers in advance.
Search this forum for 'watercooling'.
There's a good few threads with some very good recommendations.
Yeh, just looking through them now. Can't seem to find something that matches my needs as of yet. Guess i'll have to keep looking.
You'd be better going custom. The Apogee block isn't the best for the quads (D-Tek Fuzion or EK Supreme would be). The rad and pump are grand, tho you may want to look at a Thermochill 120.2 rad if you're putting the GTX into the loop.
I also vote for a custom set-up, and am also cooling a Q6600, 8800GTX, and Northbridge:)
Using
Thermochill PA 120.3 radiator + 3 Scythe S-Flex (1000RPM) Fans on Controller
Laing DDC Pump 3.1 with XSPC Res Top
DTek Fuzion CPU Block
Dangerden 8800GTX Block (although the EK block is probably better)
Custom NB Block (EK make a very nice block for your board)
CPU @3.4 GHz runs at 30c idle and 46C 100% load (air temperature 20C) with this setup and its pretty quiet
Problem is getting the PA 120.3 in your Thermaltake Armor is not totally straightfoward
http://forum.ncix.com/forums/index....646846&product_id=0&forumid=116&pcbuilderid=0
You might get away with a PA 120.2 radiator but I think it would be pushing it. You will be dumping around 300 Watts in to your water loop with that set up. Here are a coupling of graphs comparing heat dissipation and fan performance for PA 120.2 vs PA 120.3
http://www.thermochill.com/PATesting/PA1202HeatdissVSFlowrateGPM.jpg
http://www.thermochill.com/PATesting/PA1203HeatdissVSFlowrateGPM.jpg
Using
Thanks for your post, great advice.What case are you using?
Thanks.
Value for money though the swiftech kit is very good and the cpu block, although not the best, is within a couple of degrees of been the best.
A very good kit for a first time watercooling and cheaper than a custom setup.
Surge's recommendation is the best of the best and if you can afford it plus want to overclock to the max then that's the one to go for.
I have a very similar setup to the swiftech kit but bought it all 2nd hand for less than £100 and I am happy with 55 degrees at 3.5Ghz on my quad and total silence plus 43 degrees on my g92 gts.
Is that 55 Load temps i am assuming? Prime95+ stress test temps also 55C?
Thanks again for your advice. You guys are very helpful.
Thanks- your'e welcome :)
Case is a Lian-Li PC-G70 which is huge! PA 120.3 fits in the roof with the PSU at the bottom. I will take a couple of pictures and post them for you but can't do that til later this pm or tomorrow am
Cheers
Geoff
Yeah load temps. No point quoting idle temps as they are irrelevant imo. Running prime95 samll tfts for 8 hours.
OKay, last question.
What would be the absolute best case to put a high end water cooling setup in? I might as well do it properly and get a new case as well as I not that keen on the thermaltake I have. Ideas are welcome :).
mountain mods or Lian Li PC-343B
both are large cube cases and require deep pockets.
Wow they are big!! What about just sticking to standard width cases?
I was on the verge of getting a Lian Li PC-343B, but the girlfriend played the VETO card, mentioning the fact we are saving for a mortgage, and that fact it probably need a house of its own.
so now I have the Armor apart trying to fit the PA120.3 in it, its very tight.
