Water cooling Or Not
colour aint a problem for me, results looking for tbh, didnt know u could mix that way 50/50
always good advice here :) cheers
Well, if it's results you're looking for, I'd say just stick with the water for now, and leave the eco6 on the side. I'm not actually 100% about the mixing, but I don't see how it could be a problem.
Seeing as this is your first time, I think that for the first time you fill the loop, distilled water would be best.
2x 1 litre bottles uv blue :)
Hi Rab, l chose the ECO6 Clear as it had no dye in it, peeps had trouble with with cooling fluids contianing dye. Some one could be a bit more pacific about it, if you want to use ECO6 send it back and get the Clear.
Like l say its been in my loop just over 4 months and its still as clear, etc as the day l filled the loop.
Its recommended not to mix anything with ECO 6.
well finally got it set up, some parts came l8, wasnt cheap. but overall happy with it, pc a lot quieter & temps are big improvement. any benching done to test, none of the cores went over 56C around 10-12c drop.
