25 Mar 2014 at 09:53 #1 Zairs Zairs Associate Joined 3 Jan 2010 Posts 1,945 Location Hailsham Can I add a custom water cooling setup into this case Last edited: 25 Mar 2014
25 Mar 2014 at 11:25 #2 mjones1 mjones1 Soldato Joined 4 Jan 2009 Posts 4,147 Looks like you could get a 360mm rad at the front if you are willing to cut a opening through your drive bay floor.
25 Mar 2014 at 11:26 #3 frostdragon frostdragon Associate Joined 17 Mar 2014 Posts 241 240mm rad at front is possible
25 Mar 2014 at 12:15 #4 Zairs Zairs Associate OP Joined 3 Jan 2010 Posts 1,945 Location Hailsham I don't mind altering what's already there. Is bigger better on water cooling or is there more factors involved.
25 Mar 2014 at 17:01 #5 deFiniLoGy deFiniLoGy Soldato Joined 7 Mar 2013 Posts 3,321 Location Caistor mjones1 said: Looks like you could get a 360mm rad at the front if you are willing to cut a opening through your drive bay floor. Click to expand... ^that Or maybe you can put 1 240 rad at the top + 1 at the front if you don't wait to cut open the case. Seeing you only 1 display card + cpu loop, 2*240 rad should do the job for you I guess.
