- 19 Nov 2008
guys what would you suggest for a quiet water cooling build.
it will properly contain gpu cpu and two thermochill 240rads
i am looking at the MPC350, MPC355 and the MPC655.
the MPC350 and 355 will have the XSPC res top on it as they are meant to be good for noise and flow.
i think all 3 are powerful enough for the loop, but how noisy are each of them?
i know the MPC655 can get noisy on setting 4-5.
can the MPC3XX's speeds be changed or are they fixed and how much louder is the 355 to the 350.
Thanks.
Thanks.
