- 14 May 2007
I am currently running three 1/2 loops for my system, each with its own 240mm rad, and xspc 1000 pump.
What i am looking to do is convert this into a single possibly dual loop.
I am cooling: -
Will be quad core currently swiftech apogee e6600, penryn/ phenom (when i upgrade soon).
hd2900xt with aquagratix block (already have this
DD maze4 chipset block.
I was looking at pumps and it seems the Alphacool ap1510 has specs far in excess of the D5. I can't find any reviews, good bad, or otherwise of this pump. The lift height of 6m sounds good, as the aquagratix block i have uses g1/8 thread, that i have converted to 1/2" but is still very restrictive i feel.
What i really want is a really really powerful pump to do this: -
res>dual rad>cpu>dual rad>vga>dual rad>chipset>res.
Alternatively, i could go for a dual loop, putting the gpu on its own loop.
I am using a mozart TX case, so space isn't such a concern.
I am cooling: -
