I have purchased the gear ready for my new build (see Sig). I will be cooling the CPU and GPU using one loop with a XSPC RX 360 Radiator.... the question is:
Will this be sufficient to cool both the i7-2600K and Sapphire HD 6990 using one loop?
If so, which direction of flow. Should it be:
1. Res/Pump -> GPU Block -> CPU Block -> Rad -> Res/Pump
2. Res/Pump -> CPU Block -> GPU Block -> Rad -> Res/Pump
3. Res/Pump -> Rad -> GPU Block -> CPU Block -> Res/Pump
4. Res/Pump -> Rad -> CPU Block -> GPU Block -> Res/Pump
Or should I split the flow through a Y connector to both the CPU and GPU so that they are both getting equally cooled fluid? Although on that note I do understand that the liquid will choose the path of least resistance so one block may get starved of coolant.
Thanks in advance.
Thanks in advance.
