Water Cooling Questions from a Noob
14 Nov 2005
I've just got muself a new water cooling set up. :D . Now the questions. I will be cooling a 7900GT, a E6300 and a 965p North Bridge. The setup comes with a 120mm Radiator and 2*120mm radiator, now as i understand stand it the reservoir must go before the pump but where should i put the 2 radiators should i have them side by side or in different positions in the loop for that matter where in the loop should i put the 3 water blocks.
My last question is i haven't yet got any coolant / anti algea fluids is it safe to run the system temporairily just on de ionised water for maybe a couple weeks.
i apologise for the probable stupidity of the questions but i really dont want to mess me system up.
Cheers
Why do you have a northbridge block? You shouldn't need one.
Who made the kit?
I wouldn't use the smaller radiator, the big one should be enough.
Unless the answer to question 2 is Thermaltake in which case you're screwed whatever you do.
3 120mm rads?
or do u mean 1 120m rad and 2 120mm fans?
As MikeTimbers sais..if you have thermaltack give up all hope now. :p
the NB block is kinda a flow killer and have an extra rad is also a flow killer too. you are also going to have to fit it all in your case so going to get quite messy with all that tubing.
i would not use the single rad just use the dual rad and would probably go...
Res --> Pump --> CPU (After the Cpu i would get a Y-Connector and go parallel setup with the GFX and NB to impove the flow) then Rad --> Res
Alo depends how loud the chipset fan is, you may not need the Chipset WB and it adds a lot of resistance and extra plumbing.
Mount the rad in the top or front of the case drawing cool air in. Flow path as Wingz describes is good.
De-ionized water is ok, but you may need some inhibitor in there soon, get some Red Line Water Wetter (RLWW) soon.
The CPU block has 2 outlets and 1 inlet can i send 1 outlet to the chipset cooler and 1 to the GPU
