- 18 Nov 2018
Hi guys I am looking for peoples input and thoughts on this matter.
I am looking to do my first hard line build in a Thermaltake The tower 900.
So I have been looking at fitting and not sure which brand to go with for hard line tubing.
Background:
My current build is :
Corsair 750D Case, Intel I7-8700k OC to 5Gz, 32 GB Corsair RGB 3666Mhz Ram, EVGA 980ti SC+ running at 1500Mhz, ASUS Formula IX Motherboard, Corsair 850AX Power Supply,Samsung Evo960 M.2, Samsung Evo 960 SSD x 2 & 1 2TB Raptor Harddrive. Dell 27" 1440P Monitor. Monsoon Bay res with EK D5, EK fittings
The CPU,Motherboard and GPU are all water cooled
I will be moving all my main parts to the new case along with, 2 new Phoba 560mm Rads & Noctuca fans, plus 2 new Reservoirs & tubing (not sure which one yet see below)
I will be upgrading my GPU once the EVGA 2080ti Hydro copper comes out if performance and fail rate does not carry on.
So my 3 questions are:
1, What is the best fitting to use?
I have been looking at both Monsoon EV2 & EK HDC,
I like the look of the Monsoon, nice clean look and no lines, as well as the double O-ring used, is it true they keep the tubing more secure with less movement (wobble) than other fittings?.
EK fittings, I use EK fittings at the moment for my current soft tubing build. I have never had a leak, drip or problems for over 2 years of taking on and off apart from some marking from use but dont have the clean look of the Monsoon and do they use 1 or 2 o rings to keep the tube still ?
Or another brand all together?
Does size really matter in a case this size ? between 12/13mm and 16mm tube & fittings?
2, What type of Tubing to use?
I am also on the fence on what type of tubing to use,
I like the sound of PETG as its lower melting point and you have more flex in it but worried about pop off and deforming at temps over 60C
Acrylic worries me regarding splits and cracks when cutting, harder to heat up and bend and if I need to move the case about.
At present my water temps are around 35-40 after a long gaming spell.
3, What Reservoirs to use ?
I have 3 in mind, all to be mounted Vertical at the front of the case.
Thermaltake Pacific PR22-D5 Silent (Very similar to the Monsoon but has the internal tube return built in)
Monsoon MMRS 300mm using the Single Port End Cap with Dual Side Ports ( worried about water noise if not kept totally full all the time and having to blank off one port)
EK-XRES 140 Revo D5 RGB PWM with the following upgrades,EK-RES X3 - TUBE 400,
EK-RES X3 - Multiport TOP & Internal Tube 12/16 200mm
So any input would be great Thanks
Background:
