Right then,
I've bolted my rad into my Lian Li by fabricating a bracket that utilises the HDD cage thumb screws & holes
I understand than you dont want have the fan too close as you get dead spots & turbulance noise.
So i've mounted the fan a couple of inches away, with the intention of making a tunnel / shrowd to direct the air flow.
does this look ok or have i missed the point completely
