hi guys, right im in the process of water cooling my rig
I've got these part atm
Heatkiller Waterblock Revision 3
XSPC Dual DDC Bay Reservoir
1/2" Compression Fittings
1/2" Tubing
all i need is a pump and rad oh and coolant which i'll do last on the list
My plan is to use 1x XSPC RX120 120mm rad on the rear fan in my Antec 900.
I've been thinking about mounting a another RX120 in the front of the 900 behind the fans which i would need to remove the hdd's bays and mount my 2 hdd's at the very bottem of the case then mount the RX in the middle.
How good would that be tho 2x RX120 rads ?
Now im thinking if i can get a 120 in the front i could mount 2 in there using a swiftech rad Clicky
What do you think ?
1/2" Tubing
What do you think ?
