I am currently looking to buy a watercooling solution for my soon to be new PC. I will be running and I7 920. And possible expansion to gpu cooling in future.
The case i will be using will most likely be a corsair obsidion
This is what i have chosen just wondering if people could suggest any changes.
Swiftech Laing D5 Vario MCP655 12V DC Pump
Thermochill PA120.3 120mm Triple Radiator £61.99
EK SPIN Reservoir EK-Bay - Plexi £45.99
EK Supreme i7 Clear Top CPU Water Block
Fluid XP+ Extreme Alien Green UV 944ml (32oz)
Akasa AK-FN057 Apache Super Silent 120mm Fan - 4 Pin PWM x 3
Arctic Silver 5 Thermal Compound (3.5g) £6.89
TFC Compression Fitting G1/4" Thread 1/2" ID/3/4" OD - High Flow x 8
Masterkleer 7/16" Tubing - 1m £2.29 x 3
Also what will be the best fan layout for the case using a 120.3 rad.
