** Water Cooling Sale**
7 Feb 2011
Stoke on Toast
Got some stunning water blocks for Titans and 780ti's at some great prices
Click here for full range
Few examples for you
Aqua Computer Kryographics for GTX Titan Black, Grey Acrylic Glass Edition Nickel Plated @ £71.99 inc VAT
Combined GPU/RAM/VRM-cooler for graphics cards of the type nvidia GTX 780 Ti with 3072 MB RAM according to reference design.
This cooler combines the features of a graphics chip cooler and RAM-coolers in an elegant and very flat watercooler. Additionally the voltage regulators are also cooled effectively.
The kryographics for GTX 780/Titan water block offers outstanding cooling performance and a low flow resistance. All mounting threads are equipped with spacers for easy installation and to prevent twisting the graphics card. The areas contacting the GPU and RAM modules are polished for excellent heat transfer. For the voltage regulators, a thermal pad with high thermal conductivity is included.
The kryoconnect water block series features a delrin connection terminal that has a significantly reduced flow resistance compared to the previous aquagraFX series. The terminal is fastened to the water block by three screws and has G1/4 inlet and outlet ports on each side for flexible installation. Two sealing screws are supplied to seal the unused connection threads. The terminal can be replaced with kryoconnect kits for SLI configurations (art. no. 23551, 23552 or 23553, not included in delivery).
Materials:
Base part: Copper, nickel plated
Top cover: Acrylic glass with stainless steel frame
Terminal: Delrin
Scope of delivery:
cooler without connectors (screw threads G 1/4)
mounting material incl. thermally conductive pad
two sealing plugs for unused connection threads
Please note:
Graphic card and fittings are not included in delivery, please order separately. Threads are G 1/4. Thermally conductive paste is required for installation.
Was £98.99 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
Aqua Computer Kryographics for GTX 780 Ti - Black Edition @ £69.95 inc VAT
The kryographics for GTX 780 Ti water block offers outstanding cooling performance and a low flow resistance. All mounting threads are equipped with spacers for easy installation and to prevent twisting the graphics card. The areas contacting the GPU and RAM modules are polished for excellent heat transfer. For the voltage regulators, a thermal pad with high thermal conductivity is included.
Materials:
Base part: Copper
Terminal: Delrin
Scope of delivery:
Please note:
Was £98.99 Inc. VAT
Only £69.95 inc VAT.
ORDER NOW
Will be adding more items to this thread as the week continues.
