The res/pump combo is not very powerfull and will definitely not perform well with the CPU loop as you have chosen one of the most restrictive blocks on the planet. Either change the CPU block to something less restrictive or upgrade the res/pump combo. You should be fine for the GPU loop.
I'd like to get an opinion on this as well, although for a Socket 775. A write up I read on the EK block showed good temps, but high flow resistance. Better flow resistance on the D-Tek Fuzion with the temps only slightly higher.
Would a D-Tek Fusion be ok with that res/pump combo?
The EK supreme is one of the best cpu blocks out atm but it needs a good pump to go with it. The Swiftech GTZ comes very close and is much less restrictive.
