Hi all,
I'm a cooling noob, and would love to hear your opinion on how to best cool a box I'm assembling. Here's what I've got so far:
Mobo: Intel D5400XS
CPU: QX9775 x 2
Chasis: Lian Li PC-V1010 (Super-Midi Tower)
Power: Tagan PipeRock TG1300-BZ 1300w Modular BZ
And planned but not yet purchased:
4 x 4GB 800MHz FB RAM (undecided as to make at the mo)
1 x Intel X25-M SSD (80GB) (for boot-up)
4 x 1TB SATA HDD (undecided as to make at the mo) (in raid-z for data)
1 x LG GBW-H20 Optical drive/burner
So, I want to liquid cool both CPUs and SB/NB chipsets. I haven't purchased the FB RAM yet, but I want to cool that too. I'm not a gamer, so cooling the GPU is not an immediate concern, but something for the future.
So here are my noob questions, sorry I have so many!
1. What RAM do you recommend? I want 4x4GB, and the main concern is that I can cool it well using something like the Koolance RAM-35 coolers, so if the FBDIMMs come with a heat spreader I'll need it to be removable.
2. Considering your answer to Q1, what do you think is the best RAM cooler to use?
3. The only SB cooler I can find which will also cover both the nForce chips is the one from DangerDen. Any others you can recommend?
4. Koolance offer CPU and NB water blocks for the D5400XS, but I've no idea what would be considered "good". Has anyone got recommendations? I've read that a good block with larger internal surface area (e.g. dimple-stamped) can make a difference of 8 degrees compared to an average block.
5. I'm planning on 3/8in (9.5mm) tubing. Sound ok?
6. Apart from what I've mentioned, can/should I think about cooling anything else (voltage regulators, mosfet, etc)
7. The big question - how the hell do I cool all this?
I'll oc the CPUs a little up to 4GHz to start with, and with the FBDIMMs and chipsets I'm gonna need to move a lot of heat. I have no objection to attaching an external radiator to the back of the chassis if a suitable one won't fit in the case. I was thinking that the stackable rads from Swiftech might be a space saver, along with their MCP655 pump with a speed controller. But the truth is that I've no idea of the power of pump or size of the rad I'll need to do the job well, or if any available kit or all-in-one external cooler will do the job. Any solution should be powerful enough to handle cooling for a couple of GPUs if I add them in later. I'm not afraid of getting my hands dirty putting something together, I'll just be leaning heavily on this forum over the next couple of months for help!
8. As I said, I'm not a gamer. This box is primarily for work, so the quieter the cooling solution, the better. I've read that some pumps can hum/vibrate fairly loudly.
9. Is it a no-no to cool skulltrail CPUs, chipsets and RAM on a single loop? What about the GPUs (when I add them) - is there a typical "best practice" for looping around 2 CPUs and 2 GPUs?
10. Is liquid even the right thing to do, or could (high-end) air adequately cool a skulltrail within the space my chassis affords, and do so quietly?
Ok, I think that'll do for now. Thanks for reading this much, and I know some of the answers won't be quick, so thanks in advance for taking the time to share your experience. If I ever get the whole thing up and running, I'll be back for overclocking advice
cheers,
Alp.
Mobo: Intel D5400XS
CPU: QX9775 x 2
cheers,
Alp.
