Hi there,
I have a zalman resorator 1 and have been using it for the last 4 years or so, and I've recently moved from a relatively large room to a relatively small room and have suddenly really started noticing a smell coming from the watercooling loop.
I think primarily it's coming from the tubing, but I'm not sure whether it is the tubing itself or the liquid that's been used (distilled + zalman anti corrison solution) that's causing the smell.
Has anyone else ever noticed a problem with either the tubing or the liquid specifically? and if so has anyone got any advice as to what tubing/liquid to go with to try and remove this smell?
Thanks in advance.
Thanks in advance.
