Evening all. I was wondering if someone could give my spec the once over
and maybe answer some questions I have. I was going to order one of those
kits from the ek website but decided that they are based quite far away,
which would be a pain if I had to send it back so I decided to order from
UK based companies instead. Anyway, on with the spec.
CPU Block: EK Supreme HF
Radiator: EK Coolstream RAD XT 360
Pump: EK DCP 4.0 (12v DC Pump)
Reservoir: EK Multi option Res X2 - 150 Advanced
Fans: Undecided
Tubing: 3/8" ID 1/2" OD Undecided on colour
Fittings: All compression
The rad will have to be mounted externally due to the size of my case,
probably attached to the back using a rad box. But eventually I'll either
get a bigger case or mount the rad behind my desk similar to the way
JohnTedd has done here.
I imagine it's safe to say that the pump would be able to cope with going
from rad to cpu to res. If I wanted to expand my loop to cool my gpu and
(maybe) add another rad would it be able to cope with
rad(360)>cpu>rad(120/240) >gpu(or 2)>res. I'm just wondering what it's limits are.
Also looking for some advice on fans. I was going to go with Enermax or
Akasa Apache, not sure though.
Cheers,
Dave.
Fans: Undecided
Cheers,
Dave.
