Greatly appreciate some advice on my proposed first water cooling spec. Ideally I want to order today. It is going in a TJ07.
Does this fit together? Will there be any problems with different materials causing electrolysis? Do I have sufficient barbs at the right sizes? Do I need any more monitoring equipment ie a flow meter/alarm?
I intend to start with one loop res- pump-cpu-gpu-rad -res
Swiftech Storm G4
EK FC8800GTX with Reg Cooler - SLI Prep'd, Acetal Top
Laing DDC 3.2 Ultra with Plexitop
ThermoChill PA120.3
G3/8" O-Ring seal to 1/2" HoseBarb x2
Additional Clamp for EK Reservoirs
EK Multi-Option Res400 Rev2
Brass T-Line Plug
1/2" T-Piece
ThermoChill PS120 Performance Shroud (Black)
Shroud
!0 ft of 1/2" ID Tygon R3603 Tubing
Worm Drive Hose Clips 6 10mm to 16mm
FluidXP+ EXT (32oz) X2
1/4" BSP PerfectSeal 1/2" Fitting X2
4 pack of SelfTapping Case Thru Fan to Rad Screws x3
Total £362.54
Plus a Nexsus Prolong and a Thermaltake CL-W0033 T-type Water Temperature Indicator.
Thanks in advance
Swiftech Storm G4
ThermoChill PA120.3
Brass T-Line Plug
1/2" T-Piece
Shroud
Total £362.54
Thanks in advance
